Adding the Content Containers Module
About
Content Containers is a SmartHub module located in the modules directory - <SmartHub_root>\modules. SmartHub Content Containers replaces the Content-By-Search feature.
Note: Content-By-Search code is still supported. Any existing CBS structure will continue to function.
Supported templates are HTML (underscore)
Content Containers:
Can be rendered event-based, anywhere on the page
A single SmartHub page can contain multiple Content Containers
Configuration is based on the standard settings files (Index.js, Results.js settings files).
Modifying HTML pages (Results.html / Index.html) is unnecessary.
How to Configure the Content Containers Module
Modify an Existing Content Container
The easiest and fastest way to work with content containers is via the SmartHub UI Editor.
For information about how to access the UI Editor as well as who can access it, see How to Use the UI Editor.
Procedure:
SmartHub administrators can simply click the UI Editor link from the SmartHub ADMINISTRATION page.
Select (double-click) the page (Index.html, landing.html, etc.) you wish to modify.
BA Insight recommends you create your own custom page (within its own folder) to modify. Leave the default files as templates.
Example: MyResultsPage.html
Select the Customize ContentContainers tab from the top of the page.
Two pre-defined containers appear:
ChatBotCbs
This container controls Best Bets and other chat bot and content-by-search functions.
MainResults
Shown below.
Most common container to modify
See the Content Containers Parameters table below for details about available options.
After making changes you must click both Apply and then Save changes (bottom left corner) for your changes to take effect.
Create a New Content Container
Procedure:
To create a new Content Container, from the default Customize ContentContainers page click the '+' icon.
Enter an ID (name) for the new Content Container.
Select the Content Container type.
Select the Content Container position.
Select the Content Container settings, as desired.
Click Apply. The dialogue closes.
Click Save Changes.
| Setting Name | Default Value | Description | |
| PreviousLabel | "Previous" | The tool-tip of the "Previous" button. | |
| NextLabel | "Next" | The tool-tip of the "Next" button. | |
| SortLabel | "Sort by: " | The text displayed in the sort section. | |
| CollapseLabel | "Collapse" | The tool-tip of the "Collapse" button. | |
| ExpandLabel | "Expand" | The tool-tip of the "Expand" button. | |
| CloseLabel | "Close" | The tool-tip of the "Close" button. | |
| NoResultsLabel | "Sorry, no results found!" | The message displayed when there are no results for the performed search. | |
| UserProfileServiceURL | SH.RootLevelURL + "/Services/UserProfileService.svc" | The URL for the user profile service (required for Analytics). | |
| ContentContainers |
SampleCBSWithDefaultValues |
- | The list of Content Containers that will be rendered. The content container name is not important, you can name it however you like. |
ParentContainerSelector |
'.sh-main-results-container' | The parent selector used for the appending of the compiled template of the container. | |
| Title | 'Content Container' | The displayed name for the content container. | |
| ControlTemplatePath | SH.RootLevelURL + "/modules/ContentContainers/templates/cbsControlTemplate.html" | Content Container template path. You can customize the template and provide the path to the custom template using this parameter. | |
| ItemTemplatePicker | function (result) { return SH.RootLevelURL + "/modules/ContentContainers/templates/cbsItemTemplate.html"; } | The function which allows choosing which template to load based on the item metadata. | |
| QueryTemplate | '{searchboxquery} FederatorBackends:"*"' | The query template to use when executing the query. | |
| SourceId | 'b29924a9-ec32-4c10-8892-a544b69ee121' | The query results source ID to use when executing the query. If it is left empty the current tab ID is used. | |
| FieldsToInclude | 'clickUri, title, Rank, ContentSource, FileExtension, excerpt, SDFUrl, date, DisplayAuthor, isUserProfile, WorkEmail, Title, JobTitle, Department, AboutMe, escbasecrawurl, UserName' |
These are If you want to return all existing properties of an item use "ALL" as value for FieldsToInclude. |
| RequestedNumberOfResults | -1 |
This specifies the number of results that are requested in a query. If the value is set to -1, this setting is disabled and the number of requested results are controlled by the RowsPerPage setting. Note the following regarding pagination:
| ShowRowsPerPage | false | When this is set to "true", the Rows per page control will be available to users to change the number of search results returned. | |
| RowsPerPage | 10,20,50 | This is a list of numbers that specifies the amount of items that are requested during a query. By default, the initial amount of items requested is the first value from the list. The RowsPerPage control will show the values of this setting as options to be selected. | |
| RowsPerPageLabel | "Results per page: ".toLocaleString() | This specifies the label text that appears before the dropdown control that allows the user to select a number of items. | |
| EnablePagination | false |
true - Pagination control is displayed on the container. false - Pagination control is hidden. |
| EnableSmartPreviews | true |
true - SmartPreviews functionality is enabled. The items support showing a binoculars icon which shows the SmartPreviews Viewer when clicked on. false - SmartPreviews functionality is disabled. |
| ShowSort | false |
true - Sort control is displayed on the container. false - Sort control is hidden. |
| AllowUserActivation | true |
true - Container shows in the "My homepage" section and can be disabled or enabled by the user. false - User cannot choose to enable or disable the container. The container is visible by default. |
| SortProperties | 'Rank#Most Relevant#descending,date#Newest#descending,date#Oldest#ascending' |
This specifies a comma separated list of properties available for sorting. These must be sortable properties in the search engine. The first property in the SortProperties list is used as the default sort property. The SortProperties setting supports the following formats:
| TriggerNewQueryOn | 'afterInitialization' |
The name of the event that, when triggered, will execute a new query and render the results. If left empty, then the Container only renders after being invoked via API. Examples of events: afterInitialization, deferredQuerySuccess or any custom event. |
| EnableCountTotal | false |
true - The total count is displayed on the container. false - The total count is hidden. |
| EnableContentIntelligence | true |
true - ContentIntelligence functionality is enabled. The items will support showing an info icon which shows a modal with details of the result when clicked on. false -ContentIntelligence functionality is disabled. |
| EnableResultFeedback | true |
true - ResultFeedback functionality is enabled. The items will support showing a feedback icon which shows a feedback form when clicked on. false - ResultFeedback functionality is disabled. |
| EnableRatings | false |
true - Ratings functionality is enabled. The ratings of the results will be displayed. false - Ratings functionality is disabled. |
| EnablePubChemViewer | false |
true - PubChemViewer functionality is enabled. The items support showing a button labeled "3D Model" which shows the PubChem Viewer when clicked on. false - PubChemViewer functionality is disabled. |
| Baskets | {'.basketButton':false} |
true - Baskets functionality is enabled. The items will support showing a button labeled "Add to basket/Remove from basket" which adds/removes the item to/from the basket when clicked on. false - Baskets functionality is disabled. |
| IsMainResults | false |
true - The content container contains the main results. false - The content container doesn't contain the main results and behaves like a normal CBS. |
| DeferredRendering | false |
true - The ContentContainer does not render the results, instead it triggers an event named "ContentContainerDeferredRendering". This event will contain the information about the container Id, container settings and the results, and can be used to handle the result rendering via a custom function. false - The ContentContainer will use its internal methods to render the items. |
Content Containers events and functions
You can use the following events and functions to implement custom changes to your ContentContainer module:
ContentContainer events
All the ContentContainer events can be seen in the SH.ContentContainers.BuiltInEvents object in the ContentContainer.js file.
| Event | Description |
| ContentContainerBeforeInitialization | This event is triggered before the ContentContainer starts rendering. |
| ContentContainerDeferredRendering | This event is triggered before the results are rendered when the DeferredRendering content container parameter is true. |
| ContentContainerBeforeQuery | This event is triggered before doing a query using SH.SearchProvider.GetDocuments. |
| ContentContainerQuerySuccess | This event is triggered after ContentContainerBeforeQuery and before rendering the results. |
| newResultDisplayed | This event is triggered when a result is rendered. |
| newResultsDisplayed | This event is triggered when all the results are rendered. |
Exposed ContentContainer functions
All the exposed ContentContainer functions can be seen at the bottom of the ContentContainer.js file.
| Function | Parameters | Description |
| SH.ContentContainers.Close | containerId | This function hides the ContentContainer with the specified id. |
| SH.ContentContainers.Show | containerId | This function shows the ContentContainer with the specified id. |
| SH.ContentContainers.RenderContentContainer | containerId, ev, containerSettings, showUserPredefined Result, callback | This function renders the ContentContainer with the specified id. |
| SH.ContentContainers.RegisterNewAction | e, newActionConfiguration, callback | This function creates and renders a new action inside the action bar for a result. |
| SH.ContentContainers.GetContentContainers | - | This function returns the SearchInterface, Results and the content container ID for all the rendered ContentContainers. |
| SH.ContentContainers.GetContentContainersKeys | - | This function returns the ids for all the ContentContainers. |
| SH.ContentContainers.GetContentContainerConfiguration | containerId | This function returns the configuration for the ContentContainer with the specified id. |
| SH.ContentContainers.GetMainResultsContentContainerId | - | This function returns the configuration for the main results ContentContainer |
| SH.ContentContainers.RefreshCBS | containerId, containerSettings, startRow | This function performs a new GetDocuments Query and renders the results inside the specified ContentContainer. |
| SH.ContentContainers.GetContentContainerById | containerId | This function returns the SearchInterface , Results and the content container ID for the specified ContentContainer |
| SH.ContentContainers.ApplyDefaultSettings | containerSettings | This function applies the default ContentContainer settings for all the configuration options that are missing |
| SH.ContentContainers.GetSortCriteriaForMainResults | containerId, containerSettings | This function returns the sort criteria for the main results. |
| SH.ContentContainers.GetSortCriteriaForCBS | containerId, containerSettings | This function returns the sort criteria for specified ContentContainer acting as a CBS. |
| SH.ContentContainers.getNumberOfPages | totalResults, rowsPerPage | This function returns the number of pages. |
| SH.ContentContainers.GetFieldsToInclude | containerSettings | This function returns the fieldsToInclude configured for a ContentContainer. |
| SH.ContentContainers.UpdateConfigurationOption | containerId, settingName, settingValue | This function changes the value for the specified configuration option. |
